ArcGIS Connection Crash When Opening ArcGIS Explorer
8946
8
07-31-2013 06:49 AM
AdamGuo
Any have this issue of "ArcGIS Connection has stopped working" when opening ArcGIS Explorer?
It's becoming a constant thing with my users who only have Explorer installed on their machines.
For some reason there is no issue if ArcMap is opened first and then ArcGIS Explorer.
Any ideas?
Thank you.
[ATTACH=CONFIG]26344[/ATTACH]
Problem signature:   Problem Event Name: APPCRASH   Application Name: ArcGISConnectionBin.exe   Application Version: 10.1.2.3252   Application Timestamp: 511165ea   Fault Module Name: ntdll.dll   Fault Module Version: 6.1.7601.17725   Fault Module Timestamp: 4ec49b8f   Exception Code: c000071f   Exception Offset: 0009a3b9   OS Version: 6.1.7601.2.1.0.256.48   Locale ID: 1033   Additional Information 1: a7aa   Additional Information 2: a7aa91f17ea749d42a4de3b390fa5b3d   Additional Information 3: a7aa   Additional Information 4: a7aa91f17ea749d42a4de3b390fa5b3d  Read our privacy statement online:   http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409  If the online privacy statement is not available, please read our privacy statement offline:   C:\Windows\system32\en-US\erofflps.txt
NathanCoon
If you don't need access to arcgis online and are only using local data, delete the ArcGISConnectionBin.exe in the 'bin' folder. I've done this on installed and portable versions and it gets rid of that error.
Pretty ridiculous that with all the testing of this latest build that ESRI didn't run into this error. Between this and the program not being able to load on most machines, its almost pointless to use this software.
MarkBockenhauer
Is Windows 7 and Internet Explorer 10 also installed on the machines?
AdamGuo
Mark,
Yes we have both installed on the machines- Win 7 & IE 10. Are there any solutions right now for that?
(Also, I haven't seem to solve my labeling issue from a previous post: http://forums.arcgis.com/threads/88559-ArcExplorer-Hangs-Crashes-When-a-Layer-with-Labels-is-Added )
Thank you.
MarkBockenhauer
Running window 7 with IE9 is what some are doing.   You could also run windows 8 with IE10.  We are researching the issue with windows 7 and IE10, even when we figure out a solution it will take awhile to deliver it, we are hopeful to have the next version of ArcGIS Explorer Desktop released before the end of this year (2013).
Mark
NathanCoon
AdamGuo
That simple solution worked perfectly! Thanks!
Found that it also works for regular ArcGIS as well.
NathanCoon
Yeah when that first started happening I thought it was a conflict between Explorer and ArcGIS since they both have that file and were both trying to connect to ArcGIS Online. But turns out that the ArcGIS Connector error happens on brand new machines with only Explorer installed. And I've tested this in virtual machines, same thing.
BitsyLawhorn
Mark
Mark,
Has there been an update to resolve this?  I am still getting the error.  Thank you.
LeeStoddard
Any news on an update for this issue?
