arcexplorer symbology
3020
08-29-2014 12:45 AM
jacobochieng
when i open a map in arcexplorer, the symbology changes to exclamation marks, what could be the problem
TimWitt2
MVP Alum
Did you use some special symbology that might not be available in Explorer?
MarkBockenhauer
Jacob,
If you are using an ArcGIS Layer in ArcGIS Explorer it may be that Esri Fonts are not installed on the computer.  You could try installing the ArcGIS Explorer Fonts Expansion pack.
http://gisupdates.esri.com/ArcGISExplorer/Build2500/ArcGISExplorerFontsDownload.exe
Mark
MaureenKamau
I agree with Mark, most often in these scenarios, either the Esri Fonts are not installed or not installed correctly.
