Address Inspector Skips
2570
01-04-2012 11:19 AM
MatthewAllen
I have been having problems with the address inspector skipping portions of a road. In some cases it jumps intersections, and in other cases it will not locate an address at the beginning of a road, instead it starts in a random spot on the road (sometimes hundreds of feet away from the beginning of the road). I have tried rebuilding many times, as well as turning layers off to avoid snapping. What can I do to make the inspector follow the entire length of the road without any jumps?
MatthewAllen
Please comment if you've had this occur in your maps and you figured out how to correct this.
Thanks!
