I am trying to view related records in the table widget when I have features selected in ArcGIS Experience builder using ArcGIS enterprise version 11.3. Does anyone know a workaround for this?
Hi @Caleb_Allen_qRD ,
The action "View related records" is supported from version 11.4.
If your related records do not require an attributed relationship class, then you can use a message action to filter the related data: Record selection changes - Framework - Filter data records, and use the common field to set up the connection.
Shengdi
