Upload CSV with addresses to geocode with Add-Data-widget
1157
02-19-2025 05:53 AM
FlorianArtelt
With the add data widget in ArcGIS Experience Builder in ArcGIS Online, users can upload csv with addresses instead of coordinates, and locate them on a map. Credits are used in this process for batch geocoding and it does not matter which usertype is used.
I want to do the same in ArcGIS Enterprise. To do that I configured the Esri World Geocoder under settings within my ArcGIS Enterprise. Unfortunately it isn't working and I get the message that the upload is not possible. The Dev Tools of my browser show me an error message to contact Esri Support.
Is it generally possible to perform geocoding in the Add Data widget of the Experience Builder in ArcGIS Enterprise and what do you have to set for this?
JeffreyThompson2
MVP Frequent Contributor
I don't know how to configure the geocoding from within Experience Builder, but I am fairly certain that using the World Batch Geocoder will still cost credits even if you call it from Enterprise. I suspect the error you are seeing is related to not having your Enterprise connected to a pool of ArcGIS Online Credits.
GIS Developer
City of Arlington, Texas
FlorianArtelt
Thanks for your reply.
I think you are right, but I didn't found any option within Add Data Widget to connect the widget with my utility service.
Besides that I assumed that configuring the batch geocoding in the portal settings will make it available to all applications including the experience builder apps.
