Update on required, calculated fields in a form not presenting as required in the Experience Builder edit widget
343
01-22-2026 03:24 AM
KatyWesterberg
Are there any updates on when we can expect BUG-000178494 to be fixed? The bug means calculated fields configured with the Required check box enabled in a form configured in ArcGIS Online are not presenting as required in ArcGIS Experience Builder Edit Widget.
This was logged back in August, but the issue still persists and is causing problems for us for our data collection and the data validation we want to be in place.
Laura
by MVP Regular Contributor
Shows in review. To get emails regarding updates to the bug you can call support and attach this bug to a case/your org.
https://support.esri.com/en-us/bug/calculated-fields-configured-with-the-required-check-bo-bug-00017...
