Update on BUG-000174735
597
11-13-2025 03:27 PM
Brian_McLeer
MVP Regular Contributor
Is there an ETA for resolving this BUG? It was reported at 1.16 and is still present at 1.19 in DE.
https://support.esri.com/en-en/bug/the-order-of-attribute-fields-changes-in-the-output-whe-bug-00017...
DougBrowning
MVP Esteemed Contributor
Also adding on this one where export to CSV is using the field alias on export.  Any spaces will break most things that we use a CSV export for.
https://community.esri.com/t5/arcgis-experience-builder-ideas/table-widget-export-to-csv-is-using-th...
Default to field name for CSV should be standard.  But for now we have no way to fix this at all and had to make our own export tools.
Adding an option like in Pro to flip between Alias and Field Name would be great.
https://community.esri.com/t5/arcgis-experience-builder-ideas/add-ability-to-show-alias-or-field-nam...
thanks
