Trying to use a button to clear GraphicsLayer using GraphicsLayer.RemoveAll(). What am I doing wrong?
1222
03-20-2025 02:07 PM
LClark1102
I'm trying to build a custom widget that gets the coordinates of a map when the mouse is clicked and adds it to a graphics layer called gLayer. In the return statement, I added a button with an onClick event that calls a function named clearResults. The clearResults function runs gLayer.removeAll(), which I think should clear all features that were previously added to gLayer. New features are added to the layer without issue, but when I click the button to clear the layer, nothing happens. Can anyone inspect my code and help me figure out what the issue is?
Thanks in advance!
/** @jsx jsx */
import { React, WidgetState, type AllWidgetProps, jsx, getAppStore } from "jimu-core"
import { JimuMapViewComponent, type JimuMapView } from "jimu-arcgis"
import { Button } from 'jimu-ui'
import { SimpleLineSymbol, SimpleMarkerSymbol } from "esri/symbols"
import Point from 'esri/geometry/Point'
import Color from "esri/Color"
import Graphic from "esri/Graphic"
import GraphicsLayer from "esri/layers/GraphicsLayer"
const { useState } = React
export default function Widget (props:AllWidgetProps<any>) {
    const[latitude, setLatitude] = useState<string>('Click a point on the map. Coordinates will appear here.')
    const[longitude, setLongitude] = useState<string>('')
    var gLayer = new GraphicsLayer()
    const addGraphic = (latitude:number, longitude:number) => {
        var point = new Point({
            latitude: latitude,
            longitude: longitude
        var outline = new SimpleLineSymbol({
            color: new Color([255,255,255,0.85]),
            width: 1.5,
            style: "solid"
        var pointSymbol = new SimpleMarkerSymbol({
            type: "simple-marker",
            style: "triangle",
            outline: outline,
            color: new Color([255,53,42,1000]),
        var attributes = {
            Latitude: latitude.toFixed(5),
            Longitude: longitude.toFixed(5),
        gLayer.add(new Graphic({
            geometry: point,
            symbol: pointSymbol,
            attributes: attributes,
            popupTemplate: {
                title: "Coordinates",
                content: [{
                    type: "fields",
                    fieldInfos: [{
                        fieldName: "Latitude",
                        label: "Latitude"
                        fieldName: "Longitude",
                        label: "Longitude"
    const activeViewChangeHandler = (jmv:JimuMapView) => {
        var widgetState = WidgetState.Closed
        if(jmv) {
            jmv.view.map.add(gLayer)
            jmv.view.on('click', (evt) => {
                widgetState = getAppStore().getState().widgetsRuntimeInfo[props.id].state
                if (widgetState === WidgetState.Opened) {
                    const point: Point = jmv.view.toMap({
                        x: evt.x,
                        y:evt.y
                    setLatitude("Latitude: " + point.latitude.toFixed(5))
                    setLongitude("Longitude: " + point.longitude.toFixed(5))
                    addGraphic(point.latitude, point.longitude)
    const clearResults = () => {
        gLayer.removeAll()
    return <div className="widget-starter jimu-widget" style={{ overflow: "auto"}}>
        {props.useMapWidgetIds && props.useMapWidgetIds.length === 1 && (
            <JimuMapViewComponent useMapWidgetId={props.useMapWidgetIds?.[0]} onActiveViewChange={activeViewChangeHandler} />
        <p>{latitude}
        <br/>{longitude}</p>
        <div><Button onClick={clearResults} size="default">Clear Results</Button></div>
    </div>
Allen_Zhang
You should use a ref instead of a plain variable to store the "gLayer".
const gLayer = useRef(new GraphicsLayer())
gLayer.current.add(...)
glayer.current.removeAll()
In React, a plain variable "gLayer" is a new one in every render.
Allen_Zhang
LClark1102
Thanks, that was indeed my issue. I had a feeling it might have something to do with how I was storing the layer, but I'm still new to using React so I'm still learning some of the concepts with it.
Much appreciated!
