Triggering data actions from a custom widget
6837
14
09-23-2022 07:15 AM
MaxDiebold
I want to enable a custom widget to consume the "View in Table" data action provided by the Table widget, but I don't want to use the DataActionDropDown component. How do I trigger the action programmatically? I don't see any methods to do so in the DataActionManager class.
MaxDiebold
Never mind, figured it out. Once an action object is obtained from
DataActionManager.getInstance().getActions();
 and the specific action is found, its `onExecute()` function can be called directly.
MaxDiebold
chapmunnhsc
Max -
How did you import the DataActionManager? Where does it come from? There is like zero documentation on it. Also, did you figure out how to pass a Feature Layer to the Table action?
Thanks
chapmunnhsc
import AppDataActionManager from './lib/app-data-action-manager';
Might answer my own Q.
JillianStanford
Hello @chapmunnhsc !
This is a few months old but did you get this functionality working?
I managed to get the View in Table data action but I can't quite figure out how to pass in my feature layer.
Thank you!
chapmunnhsc
@JillianStanford -
I didn't figure it out! I think I duct taped together a solution. However, I'm not at the point where I want to add a client side feature layer to the out of the box Table widget.
Any chance you know how to do that?
JillianStanford
Hi @chapmunnhsc,
Thanks for the reply.
I'm in the same boat and cannot figure it out! I'm finding developing for this platform incredibly frustrating. If I could start over, I would not use it.
I think I need to create an output data source that can be consumed by other widgets but can't figure out how to get it wired up.
If I figure it out, I will post it here.
Thanks!
Jill
chapmunnhsc
@JillianStanford did you ever figure this out?
JillianStanford
Hi there @chapmunnhsc ,
I cobbled something together and posted it here - Custom Widget Output Datasource
Not sure if it's the most elegant solution but I'm relieved to have something working after months of frustration!
chapmunnhsc
@JillianStanford way to keep at it and figure it out! I'm about to ping you with another question...
