Timeline widget: how to show time as integer numbers
1613
02-24-2024 03:34 AM
FrancescoCotana
I'm using the Timline on experience builder, but i would like on the top to show just the years and not the full date. Also is there a way to make the widget consider 1 year as a step. Lets say I want to see all events in 1811 and moving the slider i want to see 1811 and 1812 how can i do that?
Setting the step as one year is not good because lets say that the beginning of my interval is 1/1/1811 the end will be 1/1/1812, while i would like the beginning of the interrval to be 1/1/1811 and the end 31/12/1811. Also i cant select 365 because some years have 366.
Can you help me?
I'm trying to build a slider as custom widget but i have zero knowledge in programming so thats too hard for me
AlexanderDanielPratama
Have you solved this issue? I'd like to help you, but in my experience using the timeline slider of ArcGIS Enterprise/ AGOL, it cannot end one year based on the day numbers.  I think is already set by default by Esri developers probably the complexity of programming and bugs.
The alternative is to set the minimum by month, but I think it depends on your data and the presentation type do you are satisfied with. Event with month, it will end in the first of the next month.
