the Feature Info widget does not correspond with the selected feature in the map.
1425
5
10-04-2024 06:35 AM
JasonBOCQUET
Hi guys, i have a problem today.
My ExB application have a 3 Section : Map, List and Analysis views.
On the map view, it's simple, a Map Widget with my "Building" WebMap and the "Building_P" layers activate.
On the list view, it's simple, a List Widget with some information about the "Building_P" layer.
On the Feature Info, it's a little bit complicated, but simply to understand, a Feature Info Widget to see the pop-up boxs information enriched by some Arcade expression , and this widget is set by the "Building_P" layer.
The problem is very simple : If I click on one of my building "Tour Montparnasse" i see the content of my pop-up box, I see the building in my List view... but in my Feature Info widget, it's absolutly not the same building.
My question is simple : WHY ???
I've test to use action in EVERY possibility, but nothing works.
(in reality, filtering when select a point on a map works, but I don't want to show off all other point when my users click on one point).
I'm using the same "logic" on another application, with society, but I used a duplicate layer to see the information on the Feature Info. I'm forced to duplicate my layer, and use it on the Feature Info to have the good information or i'm in front of a strange bug ?
Thanks !
Wei_Ying
Hi @JasonBOCQUET ,
What edition of ExB are you using? Could you share an repro app for us to take a look?
Wei
JasonBOCQUET
Hi @Wei_Ying i'm using the developer edition 1.15
It's not possible to me to give a copy of the application because we have to much private data that I cannot share.
Wei_Ying
Unfortunately I cannot reproduce your problem based on my understanding and use my data. Are you using building scene layers?
JasonBOCQUET
Hello @Wei_Ying absolutly not. It's only feature layers.
Wei_Ying
Thanks! Since we cannot reproduce based on the conversation here, I suggest to contact Esri support to give us a reproduce case.
