Table Widget
537
03-16-2026 09:55 AM
compass_cartographic
In Experience Builder via ArcGIS Online, I have a page using the Table widget.
When viewing the Table in the Map Viewer alone, I can view all 24,640 records.
On the Experience Builder page with the Table Widget pointing to the same hosted table, the option to "Show Record Count" only shows 16,101 records.
This stays static whether using the Single Page, or Multi-Page option.
Does anyone have a fix for this?  For now I have turned off the Show Record Count but it would be advantageous in my use case to have the correct count.
Thank you
Shen_Zhang
Hello @compass_cartographic , are you seeing this issue across different datasets, or is it tied to a specific one? It would be very helpful if you could reach out to Esri Support—they can assist in building a sample app to reproduce the issue, which will allow us to investigate it more effectively.
Shen Zhang
ClioClark
Hi @compass_cartographic,
Is it possible that you have the 'Filter by map extent' setting enabled by default in the Table widget? Does it always show 16,101 records even when zooming/panning around the map?
