Table widget unable to show selected record from parcel map image layer which has two related table on it
762
04-29-2025 12:46 PM
Neha
Hi everyone,
I have a question about an issue with the current application built using ArcGIS Experience Builder.
There are several layers in the web map. However, the issue is with the parcel map image layer that has two related tables.
When we added map and table widget to experience builder, the table shows all records.
However, when one selects a parcel on the map or through the SQL query , and expect the table to  show the selected records, it instead shows a blank table (no data).
We want to select parcels on the map or using SQL query in one of our widgets and see the selected parcels in the table through actions -> View in Table.
Other layers (that don’t have relates) behave correctly – they show selection in the table through “View in table” action.
Has anyone come across similar issue in Experience builder in ArcGIS Enterprise 11.3?
ShengdiZhang
Hi @Neha ,
I'm not sure about your configuration.
1. Does the table widget also show the parcel layer? Which data view are you using, the default view or the selected features view?
2. Have you added a Record Selection Changes - Filter/Select Records action to the Map widget?
Shengdi
