Table widget: only export fields shown in the table, not the entire dataset
14130
30
02-09-2022 07:40 PM
Hayley
Is it possible to for the table widget to only export the shown fields in the table rather than all the fields in the layer? I know this is possible for Dashboard widgets so some similar functionality would be super useful.
For example, I only have a few fields selected for this table:
However when I export the table, it gives me the entire spreadsheet with the raw data and even fields I had hidden in ArcPro.
Is there a way to configure this in ExB without having to reconfigure all my layers?
Thanks!
HL
JasonBOCQUET
I have no solution but i discover that if you used a table (hosted) type of elements, the table widget export only the fields that you choice.
It seems to be a problem when we try to used the table widget by using a feature service.
I don't know if it helps but this can be a way to use a strict table rather than a feature service (or both linked by group filter/action) ?
