Table widget export shows domain codes for certain fields but descriptions for others
1481
08-22-2024 12:02 PM
Jmoll
When I export to a csv some fields export the domain labels while others export the domain codes. I can't seem to find any pattern as to why certain fields export a certain way. Also in my exported file every time there is a " it is doubled to "".
Jmoll
I republished the layer and this fixed the problem!
ShengdiZhang
Hi @Jmoll ,
Can you share your data with me so I can take a look?
Shengdi
TimWestern
MVP Regular Contributor
If you create a table for the same data, does it show the same way?
If so, that's probably part of the answer.  It would be useful perhaps to be able to add custom columns to tables, using an Arcade Expression to get the right value for the domain in a column to fill in.  (But it might be possible to do this in Feature Classes with their setup I haven't had the opportunity to try that yet)
Jmoll
