Table download limitations in Experience Builder
1229
07-23-2025 06:58 AM
KelseyMills
We have an Experience builder application with a map displaying point locations and a table of all points with about 10 fields visible. Our users need to download this table daily, and the first issue we ran into was that the "Export to CSV" button downloaded ALL fields from the raw data, not the displayed view. Our raw data has over 100 fields and renders the download almost unusable for our users. Additionally, the alias name of the fields is not carried over into either the table or the download.
Some investigating in the ESRI forums led to a post history where ESRI's work around to downloading only the fields in the table view was to select the records first. This requires users to Select All... a functionality that does not exist in tables per additional forum posts I have found.
So, the work around for the work around is to add a select widget, set it to select by attribute via a preset query, and have users click the Select widget to select all rows before downloading. This is also not very intuitive for our user base. The query used is 'Object ID is not blank'
Another issue was found after implementing these steps. The user selects all rows using the select widget and Exports to CSV. The first CSV they export is mostly empty with only the object ID and lat/long populated. They click "Export to CSV" a second time and then the csv is populated with data. The second CSV file does include just the table fields.
In summary, the following items are currently impacting users and I am hoping there is a solution to some, without having to publish a view? Our organization is using Enterprise 11.4
  1. The Export to CSV result does not reflect the visible fields in the Table widget, and instead downloads all fields.
  2. The exported csv file and the table widget both include the raw field names and not the alias.
  3. After rows are selected, users have to download a csv twice, with the first one being mostly empty and the second one populated with data.
DougBrowning
Other big issue I posted here https://community.esri.com/t5/arcgis-experience-builder-ideas/table-widget-export-to-csv-is-using-th...  is that it will export the field Alias name only with no option to change.  Living Atlas team had us write out big friendly names which then gets exported to CSV, which with spaces in the field names, makes the CSV unusable in most programming - which is what people are exporting to csv for.
Marc_Patti
Glad someone else flagged this, because it's a pretty frustrating limitation. There should be an option under the csv export section that allows you to use field aliases instead of the raw name. It's not a fun conversation when you have to explain why an end user's data is nested under a column named "expr0" instead of the actual name of my custom expression.
amcbee
My organization is experiencing the same issue with exporting selected records to CSV. The first export will not include any attribute information, but the second export will.
When exporting the entire table to CSV, there is no issue.
