Swipe Tool Functionality
741
10-20-2025 09:04 AM
DylanHinton
Hi All,
I was wondering if there is a configuration in the Swipe Widget that allows for the imagery that is being used to automatically turn off when a user closes out the widget. Currently, it appears that the imagery layers which are enabled in the widget remain on even after the user closes out the swipe widget. Is there a setting I'm missing where closing out the widget tool automatically turns off the imagery as well? If not, I would suggest it as an enhancement for the future.
Wei_Wang
Thank you for your question. At this time, the Swipe widget does not support automatically turning off the imagery or other layers used in the widget when it is closed. Layers that are enabled for the Swipe widget will remain visible until the user manually turns them off.
Thanks for sharing your idea. We’ll review this requirement once we receive more similar requests. In the meantime, please contact our Support team to formally submit your request.
AyeletGreenberg
Thank you for the clarification. I would like to add my vote for this as an enhancement request as well.
Without this capability, using the Swipe widget can be more frustrating than helpful, especially for users who expect the imagery or other selected layers to turn off when the widget is closed.
Automatically disabling those layers would really improve the user experience.
Thanks for passing this along for consideration.
