Survey123 Widget: Send data, No survey questions available
6052
10
08-12-2020 02:51 PM
ebcdm
Using Experience Builder Developer Edition, I have previously updated the Survey123 widget with the following patch:
arcgis-experience-builder-sdk-resources/patches/1.0/patch1/arcgis-experience-builder/client/dist/wid...
When trying to Send data to the survey from a selection on the map, The list of 'Select a survey question' does not populate with any of the fields.
I've tested similar functionality in the ArcGIS online Experience Builder and a survey in ArcGIS Online. And this functionality was working. However, in the developer edition it is not reading/populating with the survey fields.
-Erik
KarinaLivingston
I'm experiencing a similar issue where I can see the survey and some of the fields/questions to connect but most of them are one's that I have hidden in the survey form. I don't see the fields I actually need to connect. This is only happening when I try in Portal but works fine in AGOL.
