Store Popup Data
1829
07-12-2023 04:11 AM
MartiGSYS
Hi, I need to in some way, when clicking on a Popup, store all the data of the current popup on the code. If I click on a different popup the data will overwrite with the new one.
For example, if I click on this popup I want to save the row names and the data from each row.
Thank you.
RhettZufelt
MVP Notable Contributor
you can select them with you mouse, copy/paste.  If you paste into Excel, will keep it in row and columns.
R_
MartiGSYS
Maybe I didn't explain well but what I need is to store all the data of the pop-up on a variable, so then I can work with that data on my react code. What I am trying to do is taking the value of the first row for example, and sending that value to another API, so yeah copy/paste the data manually is not a viable option, but thank you for your response.
Marti
JeffreyThompson2
MVP Frequent Contributor
The data should be stored on popup.selectedFeature.graphic.attribuites. You will probably need to set up an event handler with reactiveUtils.
GIS Developer
City of Arlington, Texas
