Sidebar(s) not visible in Full Screen Mode
2703
02-25-2022 10:37 AM
RhettZufelt
MVP Notable Contributor
In my online version of EB, it seems that the only sidebar that is visible in Full screen mode is the one with the Map Widget in it.  Even with default state = Expanded, once you hit the fullscreen button, the sidebar(s) disappear.
Am I missing something here, or is this by design/bug/known limitation?
Would really like to use the Fullscreen at times, but defeats the purpose of the App if the functionality of the widgets in sidebars are not accessible.
R_
2 Solutions
RobertScheitlin__GISP
@RhettZufelt
If you go to this link I am using the Jewlery Box template and when I F11 in Chrome for full screen it works fine for me.
https://gis.calhouncounty.org/EB/V1.7/widgets/FeaturePanel/index.html
@RhettZufelt
OK I see you are talking about the full screen widget in the map widget. So this is probably my design as it is a map widgets full screen widget so it would only take the map widget to full screen.
@RhettZufelt
@RhettZufelt
RhettZufelt
Thanks Robert,
Yes, I was using the fullscreen option in the map widget.
Did not try the F11 button.  That seems to be working fine.
Thank you yet again,
R_
