Show on map from record selection change
1064
03-14-2024 08:36 AM
SeanOTooleCT
I have an experience with a search widget that has two sources: the ArcGIS geocoding service and a feature class of common place names in the map area. I'd like to have a pin dropped in the location of either search source that is selected. This works fine for the geocoder, as it seems to work by creating a single data point layer (and "show on map" is an option for record creation). But the common place names search works on record selection, and the only options are to pan, zoom, flash, or filter. Is there a way to show a point on the map with some sort of marker when records are selected or filtered? I'm imagining a custom widget could be created, but that's well above my skill level.
Thank you!
