Search widget no longer works when using a data view.
736
02-05-2024 08:20 AM
CSevery
I am using Experience Builder to create a page for a client to view inspection worksheets.
It is helpful to be able to filter the data to search only one specific year, but once I apply the data view to one year the search bar no longer works. This is true for any data view.
EX: Search bar works with the data. I create a data view for this data in the search bar where YEAR is '2023', the search bar no longer works.
Has anyone found a work around solution?
ShengdiZhang
Hi @CSevery ,
When using a data view, although the selection between the data view and the source data is synchronized, filter actions (search) on a data view does not affect other data views or the source data.
Can you check if the search widget selects the data view while the other widget selects the source data?
If this is not the reason, can you share your app with me so that I can check?
Shengdi
