Route layer
466
09-25-2025 05:26 AM
LaboratorioGeomatica2
Hi all,
With the Directions widget I can find the path between two points, and the line connecting them appears on the screen. This line is saved automatically on a layer that's placed at the top of the layer list (Map Layers widget). Is it possible to automatically place this layer at the bottom of the list?
Many thanks
Best regards
Massimo
TianWen
You can enable the Reorder layers option in the Map Layers widget to adjust the order of the layers as needed.
