Right click on Editing on experience
931
01-16-2024 03:44 AM
AhmedJama
Hello
I used webappviewer and therefore it was recommended that I should use experience.
I was used to using smart editing and then I could click on an object e.g. flat and then right click to edit any of those properties.
Now I don't get the option to edit and it's either you click on the object or you click on edit.
Is there a possibility to add the option where you can right click to edit an object?
Greeting
Ahmed Jama
AlixVezina
Hi @AhmedJama , right-clicking is not usually an option on the web. Please could you record the behavior and functionality you are describing and share the recording here so I can better understand the functionality you are looking for?
