Removing variable tokens from text widgets?
1784
05-05-2021 06:10 PM
PeterKT
I can't seem to work out how to remove data variable tokens from my text widget when first opening the page.
The variables are change to their values once a row is selected in the list, but until then.. I get the following.
The data is dynamic changing minute to minute.
Peter T, Brisbane
TonghuiMing
Hi @PeterKT,
It seems like you want a solution for the initial state. Maybe you could try utilizing the "View for empty selection" function inside your data source.
Doc to refer to - https://doc.arcgis.com/en/experience-builder/build-apps/select-data.htm
Another similar post - https://community.esri.com/t5/arcgis-experience-builder/want-to-select-first-record-when-app-starts/... (refer to my colleague Shengdi's reply).
Hope it helps.
TonghuiMing
Hi @PeterKT,
Hope it helps.
PeterKT
Thank you.   I'm still learning ..👍
Peter T, Brisbane
