Remove yellow box on hover?
1595
01-10-2025 11:49 AM
KMathieuGIS
Hi all, I am currently using Experience Builder to create a location finder for my organization. My Experience is currently configured using the Search and Near Me widgets. I'm almost done with the project except for one little thing that's driving me nuts.
When I mouse over the search results in the Near Me widget, an ugly yellow box appears over the search result. I'm assuming this is some kind of hover feature, and I was wondering if there was a way to turn it off? All my symbology, text, and highlight colors are currently set to my org's color standards, so this looks very out of place.
Here's what I mean:
Any help would be greatly appreciated.
Kristen
Laura
by MVP Regular Contributor
Click on your layer under Analysis of the Near Me widget.
Then change the color or get rid of the highlight.
JaredPilbeam2
MVP Alum
@Laura Changing the color or switching off the highlight doesn't remove the yellow square when you hover over the Near Me results. I don't see anywhere in the Map or Search settings, the only other widgets in my ExB build, to turn it off either. I have no idea where the hover is coming from.
Laura
The dot stays but when you change the color or switch to transparent the box does goes away as I showed. This is with testing in AGOL. Not sure which version you're using.
