Redux samples
4141
07-22-2021 03:04 AM
henrilebon974
Hello ESRI,
You provide some explainations how to create a Redux store. It is a good thing.
https://developers.arcgis.com/experience-builder/guide/widget-communication/
https://developers.arcgis.com/experience-builder/sample-code/widgets/redux/
Could you provide a sample how import it and use it in an other widget please ?
It is not clear for me.
Thanks.
DaveFullerton
@henrilebon974
I was looking at the redux sample back in March.  I figured it out by copying the simple widget and updating it to subscribe to the value that the redux widget stores.  I have attached it here.  There are comments in the code indicating everything I did to update the simple widget to turn it into the simple-redux-subscribe widget.
Hope it helps!
DaveFullerton
@henrilebon974
Hope it helps!
henrilebon974
Thank Dave. It is more clear for me.
KarthikAditya
In your attached code, there's only a single widget with a redux store. Have you managed to share this redux store with another widget to communicate between them?
If you have any code snippets that can share state between widgets using a Redux store, could you please share it here, since the guide does not have that
DaveFullerton
The sample I attached works in tandem with Esri's Redux sample:
BhaveshSuthar
Hello @DaveFullerton !
Can you please help with how to access the state in functional component. I found in the documentation that useSelect hook can be used but don't know how to.
