Redirect URL Too Long Problem
608
6
03-25-2026 01:05 AM
MatsHardy
I have made an app by expenience builder on ArcGIS Enterprise 11.3. Now I would integrate the app to company's Portal with single sign-on but the problem is that the url is too long,
https://xyz.yyy.com/portal/sharing/rest/oauth2/authorize?client_id=experienceBuilder&response_type=c...
&expiration=20160&redirect_uri=https%3A%2F%2Fxxx.yyy.com%2Fportal%2Fapps%2Fexperiencebuilder%2Fcdn%2F365%2Fjimu-core%2Foauth-callback.html%3FclientId%3DexperienceBuilder%26portal%3Dhttps%3A%2F%2
Fxxx.yyy.com%2Fportal%2Fsharing%2Frest%26popup%3Dfalse%26isInPortal%3Dtrue%26isDevEdition%3Dfalse%26isOutOfExb%3Dfalse%26mountPath%3D%2Fportal%2Fapps%2Fexperiencebuilder%2F%26enablePkce%3Dtrue%26fromUrl%3Dhttps%253A%252F%252Fxxx.yyy.com%252Fportal%252Fapps%252Fexperiencebuilder%252Fexperience%252F%253Fid%253D75a083b1b3c8466580cdee8febe9f19b%26redirectUri%3Dhttps%253A%252F%252Fxxx.yyy.com%252Fportal%252Fapps%252Fexperiencebuilder%252Fcdn%252F365%252Fjimu-core%252Foauth-callback.html%253FclientId%253DexperienceBuilder%2526
portal%253Dhttps%253A%252F%252Fxxx.yyy.com%252Fportal%252Fsharing%252Frest%2526popup%253Dfalse%2526isInPortal%253Dtrue%2526isDevEdition%253Dfalse%2526isOutOfExb%253Dfalse%2526mountPath%253D%252Fportal%252Fapps%252Fexperiencebuilder%252F%2526enablePkce%253Dtrue%2526fromUrl%253Dhttps%25253A%25252F%25252Fxxx.yyy.com%25252Fportal%25252Fapps%25252Fexperiencebuilder%25252Fexperience%25252F%25253Fid%25253D75a083b1b3c8466580cdee8febe9f19b&state=%7B%22id%22%3A%22YhFcjOUqU756l5ORYTg2YFoY7ZzmpKVwNq79F7TlkPs%22%2C%22originalUrl%22%3A%22https%3A%2F%2Fxxx.yyy.com%2Fportal%2Fapps%2Fexperiencebuilder%2Fexperience%2F%3Fid%3D
75a083b1b3c8466580cdee8febe9f19b%22%7D&locale=&style=&code_challenge_method=S256&code_challenge=DoKKDG2BXSkhRicFICtMs2sTBm3kPSgEINZEfu-Nanw&
showSignupOption=true&signupType=esri&hideCancel=true&force_login=false
Are there ways to shorten the url or anything I should configure?
EMani
by Esri Contributor
MatsHardy
I have done so but the url is expanded during single sign-on. It seems the url is forward back and forth.
EMani
by Esri Contributor
Hi @MatsHardy
Can you clarify what you mean by "integrate the app to the company's Portal with single sign-on"?
MatsHardy
I haved added the company's openID to ArcGIS Portal so that users can login by both built-in account and openID. But when user open the app url
https://xyz.yyy.com/portal/home/item.html?id={app id}
The url is forwarded to the long url.
EMani
by Esri Contributor
Hi @MatsHardy
Try using the Portal item url:
https://<portal.domain>/portal/home/item.html?id=<ExperienceItemID>
EMani
by Esri Contributor
Hi @MatsHardy
Did you find a resolution for this? I have a similar case running, so I thought I'd let you know.
Can you please take a look at these two bugs to see if they match your issue or the workaround helps?
Check if you have a reverse proxy/Web Application Firewall: the block is due to the HTTP URL length exceeding the global limit, which you may be able to increase for a single application or in the global policy setting.
Check whether you have any settings that enable short URLs.
From the Keycloak Admin console, in the provider's advanced settings, you must enable the "Requires short state parameter" option. This provides a solution for the client when connecting to ArcGIS Experience Builder.
