"Maximum Categories" setting for Bar Chart widget has unexpected results using "Split by Field" option
1128
10-10-2025 01:53 PM
AaronKoelker
I'm using the Chart widget, and am trying to limit the number of categories that will display in a bar chart using the "Maximum Categories" option under the widget's Content pane; Data settings group. It is a stacked bar chart using the "Split by Field" option. However, the app/widget continues to show many more categories over the limit I've set. If I disable the "Split by Field" option, it works as intended. In the Experience Builder documentation, it only says that you must use the "By Group" category type to have this option (which I am).
I did notice that if I lower the Maximum Categories number, (for example to 5) it will show less categories in the chart, but still many more than what I set the maximum number to. In the case of lowering it to 5, it instead shows 14 in the chart (out of 40)
The settings I'm using are in the table below. Can anyone else reproduce this issue? Is there another undocumented requirement for this setting related to the Split by Field?
Category TypeBy Group
Category FieldText Field 1
StatisticsCount
Split by FieldText Field 2
Sort byValue / Descending
Maximum Categories25
-Aaron
Wei_Ying
Hi @AaronKoelker  Thanks for your feedback. This is a known limitation and we have logged issue to enhance in future.
