"Error occurred while loading this layer" in Experience Builder Developement Edition
918
05-25-2025 08:38 PM
GeeteshSingh07
I am facing issues with the ExB developer edition. All the layers in the map doesn't load and in map Layer Widget we see an error: "Error occurred while loading this layer" .
The same web map loads in Map viewer and even loads in ExB created through portal. However, it doesn't work in dev edition.
Best Regards,
Geetesh
[email protected]
Allen_Zhang
Not sure if this is your case, but I found a similar post: https://community.esri.com/t5/arcgis-online-questions/existing-layers-showing-quot-error-occurred/td...
More details would help locate the problem.
GeeteshSingh07
@Allen_Zhang , thank you for the help. it was internal CORS issue resolved by our IT by adding CORS to header or something
Best Regards,
Geetesh
[email protected]
