Query widget doesn't respect time settings?
822
11-21-2024 01:51 PM
JoshBerna
Hi all,
I'm encountering an issue with a Date field in the query widget of ExpBuilder. This field represents the time at which drone imagery was collected, format: {AcquisitionDate | MM:dd:yyyy hh:mm a}.
I have the webmap properties for this experience set to utilize the data time zone, and the experience builder set to do the same. This is reflected in other data views in the experience, like feature popups. However, the query widget displays UTC (should be MST) in spite of these settings (see example image "querywidgetissue").
This is arguably a minor issue, but I'd like to maintain consistency in the presentation of the data. Is it known that the query issue doesn't honor the application's time settings? Is this a possible bug unique to this experience?
I explored using custom results for the query widget, rather than the webmap's settings, though I am under the belief that there is no way to adjust for this inconsistency using dynamic text.
Anywho, any insight on this is greatly appreciated. Thank you for reading.
