Printing Widget not working in experience builder
62
12 hours ago
NizamGIS
Good Afternoon
I have installed ArcGIS enterprise standard 12.1 and want to do printing facility on the dashboard developed in experience builder. I used geodatabase of projection in international feet
"WGS_1984_UTM_Zone_43N_Foot_INT", even after the setting the project into WGS1984 but no avail.
When I fixed the printing widget in experience builder and perform the task, received the following error;
I checked the ArcGIS Server Manager tools, it is working. the log detail is given as;
but if all layers off then printing widgets working.
please guide what is the actual issue
regards
Nizam
JayasriB
Try turning your layers back on one by one and running a test print after each. As soon as it throws that error again, you will know exactly which layer is breaking the schema.
Once you find the broken layer, check if its coordinate system matches your map or if it needs to be re-published with standard projection parameters.
JayasriB
Causes of error might be Spatial Reference Mismatch, Unsupported Layer Types / Token Issues or Complex Feature Geometry
