Portal Web Map Overwriting (ArcGIS Pro vs Map Viewer)
824
08-07-2024 11:35 AM
KenStocks
Is there a matrix available that lists what will break when an existing Portal Web map is modified by ArcGIS Pro followed by the Map Viewer, followed by Pro, Map Viewer, repeat?  Are there any versions of ArcGIS Pro and Map Viewer that are completely compatible (updating one or the other will not break previous configuration)?  I am trying to understand what will break if you have to make a web map update using ArcGIS pro.
Is there a workflow to minimize rework due to incompatibility between Portal Web Maps modified by ArcGIS Pro and Map Viewer?  I am working with Pro 3.1.3, Enterprise 11.1, and using the web maps in Experience Builder 1.14 Dev Edition.
Thanks in advance for any help here!
Spencer_PercivalPercival
I too am curious about this. I am currently creating web maps from pro with published services. I can publish and save those web maps in pro, but am running into issues when updating the web map in Portal and then bringing them back into pro, making more changes and the save fails on the "Convert CIMMapDocument to JSON" step.
