Locate button not displaying on smaller screens
318
07-09-2024 01:14 PM
RossFindlayCOC
I am curious if this was by design? When configuring my mobile experience I toggle the "Locate" button on the Map Widget. However, as a best practice I tend to make my custom layout to operate with the smallest stock size. In doing so, I am unable to display / fit the Locate button if my Map Widget is smaller than 600px.
The next screen size allows for the Locate to display.
What are my options here?
TonghuiMing
Hi @RossFindlayCOC
There is a similar support ticket about that (ENH-000167428) and we are evaluating the enhancement possibility. Thanks for bringing this up.
jcarlson
Is it an option to remove other widgets, like the "home" button?
For our Experience projects, we often stick things like the layer list into a widget controller to keep more of the map frame clear.
You can also add two maps to a map frame widget and get a "map toggle" button in the corner to seamlessly transition between a 2D and 3D map. That could eliminate the need for a button bar at the top and recover some vertical pixel space, too.
- Josh Carlson
Kendall County GIS
RossFindlayCOC
I appreciate your input, the layout was determined months ago and there is no desire to alter it at this time.  What I ultimately would like to have the capability to have is the same experience that Instant apps has with a position manager for the map widget. Hopefully, this can be realized in the future. For now the Full Screen widget solve my issue.
TonghuiMing
Hi @RossFindlayCOC
