List Widget interaction with Survey123 Widget
1139
06-28-2023 12:18 PM
Andrew-Bowne
Is it possible to edit records from an existing survey using the Survey123 Widget if you select an item from a list widget that is tied to the same datasource?
I have an app that has a list widget showing attributes of features.   I would like to be able to select an item in the list and have it pull up the results into the Survey123 widget.  These items were originally collected using Survey123 in the field.
The only way I can get the Survey123 widget to load the data is to click the feature on the map.  I'd like the flexibility to be able to select the item in the list widget as well.
k on the map.
Marisa_Kordecki
Did you find a way to do this?
