list widget - custom arcade expressions?
2517
08-03-2020 06:37 AM
CarmenDurham
Hi all,
I am just starting to work with Experience Builder so forgive me if this is a rudimentary question.
In the basic list widget and adding dynamic content, should I be able to see and select the custom arcade expressions that I have configured for the popups for the layer in the web map?
If so, could someone tell or a screenshot of where I should see them (because I am not).
Note: the layer is being pulled from our ArcGIS server (map service).  Not a portal, just a plain ArcGIS server map service.
Carmen
shaylavi
Hi Carmen,
I don't really follow on where you problem is but have you looked into the documentation of the widget?
List widget—ArcGIS Experience Builder | Documentation
Try following this video, see if it helps you -
Get to Know ArcGIS Experience Builder: Build an Experience from Scratch - YouTube
Shay.
Shay
AdamArcichowski
I too do not see the custom Expression in the List widget that I have created in the Map Viewer.
It allows you to make expression in the List widget but it does look like you can only use 5 functions, Count, Sum Min Max.
A bit odd.
