Limit Navigation by Bounding Box Extents
940
07-12-2025 01:15 PM
Todd
I have custom bounding box (bbox) extent polygons which define certain project areas. Each project area has the same basemap datasets, but different project data. I want to design an Experience Builder template (ArcGIS Enterprise 11.3) which includes the basemap datasets and one with the bbox polygons. Intent is to prevent the user from panning outside of their respective project bbox.
How can I use these bbox polygons within Experience Builder to keep a user from panning outside the bbox extents?
Thx,
Todd
Regards,
Todd
JeffreyThompson2
MVP Frequent Contributor
I know it's in the plan to add extent limits, probably through an update to the Map Viewer, but it is not currently available.
GIS Developer
City of Arlington, Texas
D_Atkins
It's worth mentioning there are multiple threads on this very topic:
Limit the extent of a webmap - Esri Community (2025 AGOL)
And that this function was available in 2013 WebApp Builder.
Control the Map Extent in ArcGIS Online | Fall 2013 | ArcUser
Workarounds range from server-object interceptors for filtering,
Re: Limit extent of a web - Esri Community (2023)
to custom ExB Widgets,
Solved: Restrict web map navigation extent in Enterprise 1... - Esri Community.
From that last link, I might try Map frame constraints—ArcGIS Pro | Documentation, but I'd also like to see a configurable navigational extent setting in Map Viewer or Experience Builder, preferably before WebApp is fully retired...
