Layer Toggle in Experience Builder
1614
6
10-17-2025 02:26 PM
TD1
As I transition my WAB apps to Experience Builder I'm wondering if there is a layer toggle widget? In my WAB app I had a layer toggle button widget swapped between layer chosen, essentially turning the layers currently on to off and the off layers to on.
Any help would be appreciated.
JeffreyThompson2
MVP Frequent Contributor
In ArcGIS Online, your best option would be to Group your layers and turn on Exclusive Visibility.
https://doc.arcgis.com/en/arcgis-online/create-maps/organize-layers-mv.htm#ESRI_CHOICE_08C70951A5B34...
In Developer Edition, you would have many more options, as there are a number of publicly available Widgets for switching layers.
GIS Developer
City of Arlington, Texas
TD1
@jefjefthank you for the options.
Can you point me to the  publicly available Widgets you are referencing?
JeffreyThompson2
SarahRijneke
Hello,
Do you know if it is possible to turn layers on and off in a side panel in Experience Builder? I need to display my legend items at all times (even when they are not visible in the map) and would like the ability to turn each category on and off.
JeffreyThompson2
If you are on Developer Edition, I am about to release a new kind of Filter Widget that may suit your needs.
GIS Developer
SarahRijneke
Thanks for sharing but I'm using the web designer exclusively. This seems to do what I need but it looks like it's only available in developer Layer Toggle Button Widget Version 2.14 - 01/13/20... - Esri Community
