Layer can be still be selected despite pop-ups being disabled
1154
06-17-2020 08:15 PM
DianaGerberich
I have a parcel layer in a map in Experience Builder that I want to show as reference, but I don't want to be able to select it when I click around the map. I have pop-ups disabled for the parcel layer, but when I click on the parcels in Experience Builder, they will highlight in the light blue color like they are selected. Is this a bug? Or is there a way to get rid of this? Several other layers in the map were doing the same thing so I converted them to tile layers which solved the problem. However, I have been unable to do this with the parcel layer due to size and a number of other reasons. Has anyone else run into this or has anyone found a solution? Thank you in advance..
DavidMartinez
Hi Diana,
This is a known issue. We will fix this to make sure it honors the web map settings.
Cheers,
David
