June 2026 Update: Experience Builder Table Widget Header Styling Issue
214
Friday
SidneyMechling
After the recent update, I noticed that the table widgets in all of my Experience Builder apps are having styling issues. Specifically, the first column header is no longer following the same styling as the rest of the headers. I have my header text set to white with a colored background, but the first column header appears blank because the text remains white while the background styling is not being applied correctly.
LakesGISMaps
Yep, same issue here as well
NicoleJohnson
MVP
Is the white field used in the data view sort? I'm seeing the same thing for those fields. In my case you can still see the text because of the colors I've chosen, but it looks strange to have those fields be white for no apparent reason.
SidneyMechling
Yes! I'm soring by OBJECTID so that makes sense now. I hope they revert back or let us decide if we want specialized styling for sorted fields. I guess my work around for now is to make my text look similar to yours without using the white text. Thank you for sharing!
Jianxia
Thank you all for letting us know. It appears a regression from the update. We are investigating it.
