JavaScript error when using locally hosted ArcGIS Maps SDK CDN in a production Experience Builder application
3980
13
04-16-2025 11:50 AM
kendrick123
I am getting the following error when hosting a downloaded ExB app which uses a locally hosted CDN:
index.js:2 Action class widgets/common/table/dist/data-actions/view-in-table load failed. TypeError: Cannot read properties of null (reading 'trim')
at Module.w [as normalize] (init.js:116:221)
at k._sanitizeUrl (IdentityManager.js:35:388)
at k.findOAuthInfo (IdentityManager.js:13:222)
at nI.registerOAuthInfo (index.js:610:23023)
at nI.initToRegisterOAuthForMainPortalAndAGOL (index.js:610:22681)
at nI.<anonymous> (index.js:610:18494)
at Generator.next (<anonymous>)
at s (index.js:610:17219)
I have spent days trying to debug the problem with no success. The error happens if I have a custom widget and also the built in table widget inside the experience. The downloaded experience is hosted on IIS. The error does not happen on the first load but on a random consecutive load and after the error it keeps giving the same error.
Few observations:
  • The error does not surface when using CDN hosted in ESRI servers.
  • The error only happens if experience has a custom widget and the built in table widget.
  • Error disappears when clearing the cache.
  • Error disappears when updating service workers on reload.
So for some reason portalUrl value ends up being undefined and that's what's causing the error inside view-in-table but I have no idea why. I suppose it has something to do with caching and service workers.
As a last resort I did a fresh offline install of ExB developer edition 1.17, downloaded the JSAPI 4.32 and hosted it on IIS. In Experience Builder I created an experience, added the table widget and the sample custom widget that comes with ExB dev edition download and still the same error appears.
I hope that someone can shed some light into why is this happening.
JordanCarmona
We were in the same boat; we're testing and upgrading into 1.18 where we were unable to reproduce the issue. The lift should be fairly minimal for you since the calcite issues were introduced in 1.17; we haven't encountered any huge gotchas.
JordanCarmona
We're at 1.18 now without any issues; the original issue also disappeared for our 1.17 test applications after the edge browser updated.
JunshanLiu
Where do you host the Maps SDK? Under the same domain as the app?
kendrick123
Yes, both are hosted on the same machine on IIS.
