Issue with Near Me widget
897
07-01-2025 12:20 PM
Veronicampbell
Hello, I have configured the Near Me widget in my experience app and would like the results to only show layers that are currently turned on in the map. I made sure to uncheck the box 'Display all layer results, regardless of visibility', however layers that are not turned on are still appearing in the results. Is there another option I am missing, or is there an issue with this component? Thank you!
AzizaParveen1
Hi @Veronicampbell ,
This is by design and the idea is, users will only configured layers in Near Me when they would like to see the results from those hidden layer and the Setting  'Display all layers regardless of their visibility" just turns on the layer visibility in the mapo, so users can see the results on the map.
Only work around  is to remove the configuration of those layers. Is there any other reason you configured those hidden layers in Near Me?
Thanks
Aziza
Veronicampbell
Hi, I'm not sure if I totally understand. I would like the ability for users to create a buffer with the Near Me tool and only see the results based on the layers that are currently turned on in the map, and relevant to their use. I configured many layers in the Near Me tool because some user will likely want to view the results, but not necessarily every user, or for every use case - some layers are dense and can make the report quite long.
Veronica
MohanGovindaraj2
I have the same problem as Veronica. I also included many layers to the Near me widget, but results will not be needed for all at once.
Mohan
