Interact with embedded Dashboard from Query Widget
1733
03-01-2023 04:33 PM
ChrisRoberts2
Hi All
I have trawled through the Forums but still cant quite out how to do this.  I have embedded a Dashboard into EB using a url parameter (   https://xxxxx.arcgis.com/apps/dashboards/xxxxxx#key_area={Key_Area}
What I want to do is from the query widget in EB select a key area hand have to Dashboard zoom and filter based on that selection.  I have added to same data source to both the query widget and the Dashboard. I know that this must be doable but for the life of me I cant get the interaction to work.
I would really appreciate it if someone could point me in the right direction.
Cheers, Chris
TonghuiMing
@ChrisRoberts2 Query utilizes the in-house data sources, and Dashboard is an external content to the ExB app (embedded).
We have widget-to-widget interactions based on the same ds (filtering) or message/data actions [all of them are in-house], and we also support the URL control - but only from the top level to widgets (app URL param -> external embedded content).
But we have not supported the vice versa (in-house widget -> app -> external embedded content).
MichaelGaiggEsri
Query widget allows you to set the selected framework item so maybe the following answer helps you sovle your problem?
https://community.esri.com/t5/arcgis-experience-builder-questions/embedded-dashboard-zoom-to-feature...
