How do I deactivate the Edit Feature function after I make an edit in Web Experience Builder?
14577
26
02-07-2024 04:58 PM
CPaulman
Hi -
My users are drawing polygons in the map in Web Experience Builder. We have noticed that once they make an edit to the feature geometry, they cannot deactivate the edit "mode".
Workflow:
In a Web Experience Builder App with a polygon feature class (attributes and geometry editable) in the web map,
1) Click on the Edit Widget
2) Highlight Select under Edit Features
3) Click on a polygon feature and edit the geometry
4) Click "Update"
5) Click Back in the Edit Feature widget "<"
6) Clear the highlighted feature (clear selection in map frame)
7) Close the Edit Widget
😎 Click on another polygon in that editable hosted feature layer.
*****AHHHHH!!!!*****
This is where I would expect the popup window to open and the feature to highlight.
***Instead, I get the orange box around the feature. And I can move or edit it! This is not what I want.***
I would appreciate any help: How do I deactivate the "Edit Mode" so that my users can go about viewing popups without fear of moving their polygons around?
coryeicher
We are experiencing this same issue.
Here is a ticket description w/ steps:
  1. Open an exb app which has Edit widget in a widget controller
  2. Use Search Widget to search for a point feature layer. Select a search result (which in our app selects the point feature)
  3. Open Edit widget... wait for it to open
  4. Close Edit widget (I didn't perform any edits)
  5. Click on a nearby line feature
Actual: popup opens for the feature, and the edit 'handles' appear for the line feature. SCREENSHOT BELOW
Expect: popup opens. NO edit 'handles' open
6. click next arrow to open next popup (we got back multiple hits)
Actual: Popup temporarily shows 2nd feature, then disappears completely.
Expect: Popup shows 2nd feature and stays open for our viewing pleasure ; )
Here's the SCREENSHOT showing the unexpected edit handles
@AlixVezina @
CORY EICHER
www.eichcorp.com
[email protected]
RVRAdmin
It's March 2025 and Edit widget in Widget Controller still have editing mode ON even after closing the Edit widget and opening other widgets (clicking on an editable polygon activates geometry edits instead of the feature popup). This is with Single widget set in Widget Controller properties (not Multiple). Thanks.
mwartman_grey
@TianWen, back in June 2024 you previously indicated that editing mode will stop if the edit widget is placed inside of a widget container in an upcoming release. It's now May 2025 and this is still not implemented. Do you have any updates?
AlixVezina
Hi all,
Just a quick update. Now, when the Edit widget is hidden or closed by being placed inside a Widget Controller or a Sidebar for example, editing will not remain active. Here's a sample so you can see the behavior: https://experience.arcgis.com/experience/47752178d0e84a85b753c30b392b73c5/
If you click a point feature on the map, it will only be loaded to be edited when the Edit widget is open/visible on the page.
ATuckwell
Hi - This is not fully fixed I don't think.
I have 11.5 and have 2 edit buttons in the widget controller, one for editing attributes and the other for editing geometry. I am using a list for selection of the feature for editing. And the geometry is a polygon.
The solution you gave is for points only.
I still have this issue when using the geometry editor from within the widget controller. The attribute editor is fine.
AlixVezina
Hi @ATuckwell , unfortunately, the issue remains in 11.5 since this was fixed in June 2025 and the fix will only become available in Enterprise 12.0.
lah
Very frustrating this issue was reported and has been occurring since 11.1 and is still not fixed in 11.5.
