Hide points by default and use Filter Widget to show
1547
03-30-2023 01:49 PM
abureaux
MVP Frequent Contributor
I am trying to prep for the eventual discontinuation of WAB, and am exploring EB. While I try to recreate things, I am seeing that EB handles layers differently than WAB, and am wondering if there is a workaround.
Scenarios
1) WAB: Map loads empty. Toggling a filter shows or hides those points.
2) EB (same set-up as WAB): Map loads empty. Toggling a filter does nothing.
3) EB (works but not a resonable solution): Map loads showing all points. Toggling a filter drills down to that level.
Set-up
For scenarios 1 and 2:
  • I have a web map with a point layer
  • The points are hidden by default (see image below)
  • In WAB, I have a Filter widget with multiple simple filters (see image below).
For scenario 3:
  • Same as 1 and 2, but I checked the layer 'on' for the web map.
Can I get the functionality I had in WAB?
TonghuiMing
The current behavior for visibility does vary from WAB. Maybe the following workaround will help with your scenario?
https://community.esri.com/t5/arcgis-experience-builder-questions/overwrite-default-map-filter/m-p/1...
