So, I thought I was being smart, clearly failed again. 🙂
To save screen "real-estate" I thought it would be good to have a number of filters brought forward through a window. The screengrab below shows the result is correct as I apply a filter from the window, I've included the count which I used to verify it was working, however, as soon the window is deactivated (clicked off) it clears the filter.
Is there a setting, or something I'm missing to keep the filter(s) active after closing the window?
Hi Jonathan,
I can reproduce your issue and confirm that it is a bug. We will look into it.
Before this bug can be fixed, there is a work around that you can use the filter widget's icon arrangement style.
Thanks for your reporting.
Regards,
Shengdi
Hi, thanks for the response.
Have tried your suggestion, however, same result with the filter "switching off" as soon as I close the window. All filters remain active, using the other arrangements too, right to the point of clicking off window.
Looking forward to the bug-fix.
Sorry I didn't make it clear in my last reply. What I mean is that you can put the icon filter widget on the page, but not on the window.
As for the window issue, after discussion it is not an easy bug to fix (or more like an enhancement), and I'm afraid it cannot be solved in the next release.
Regards,
Shengdi
Was there ever a solution to this? I have the same problem. The filter in the window works fine, I can actually see the map update in the background. But as soon as I close the window, the map reverts back to not being filtered. I wanted a wizard style set of intro screens to step users through filtering the map, if possible. It's so close to working.
(Still wondering about this.)
@ShengdiZhang I too would be really interested in a solution to this, for the same screen real-estate and wizard format reasons as the other users in this thread @AndyWells @JonathanMcDougall
Any further updates? I'm running into the same issue and would really like to persist the filter when the window is closed.
I would also really appreciate this to be fixed. The workaround with the filter button format only works if you have one filter widget to use, while I wanted to include two separate filter widgets in a column in the window... I guess another workaround will be to make a button to open a sidebar panel with filters (a type of trigger that's already available on AGOL and on Enterprise from 11.3).
This bug is fixed in the June 2025 AGOL release.
