Filter Tool within List Widget does not filter view in map
627
08-01-2025 10:44 AM
Teri_Dane
Good day,
I have built an application through Experience Builder that uses the Map, Search, Near me, Feature Info, and List widgets. The goal of the application is to search for comparable sales from a given address or pin dropped within a specific radius. I have been able to connect all the widgets and get them to function as they should, EXCEPT the Filter Tool in the List widget. When I use the filters (SQL) I have set up, the List changes, but the Map does not. I have searched and tried all the suggestions I've seen online. Has anyone else had issues with the Filter tool in the List widget not changing the map view? Were you able to get it to work or have a workaround?
Here are screenshots of my Action items for the List widget:
The "Data filtering changes" action only allows you to choose Map and either Pan to or Zoom to.
It would be nice if there were an option to filter, as there is one when the action item is Record Selection changes.
DavidColey
MVP Frequent Contributor
You shouldn't have to do any of that.  I'm working on a list widget right now in my Online ExB and I don't have to do any of that.  The only Message action I have set up is to 'Zoom to' when the 'Record Selection Changes'.
For the List 'Data' I am working with Default, not 'Selected Features' nor am I using a view.
But I also do not have any other inter-actions.
Teri_Dane
Thank you for the response, but mine does have other actions, and I need it to filter on the map in addition to the list widget.
