FeatureLayer Error 'not a valid value for this property'
1002
10-07-2024 12:43 PM
jwilner_amica
I'm attempting to create a FeatureLayer, but I am getting a number of errors, along the lines of:
Accessor#set Invalid property value, value needs to be one of 'esri.geometry.Extent', 'esri.geometry.Multipoint', 'esri.geometry.Point', 'esri.geometry.Polyline', 'esri.geometry.Polygon', or a plain object that can autocast (having .type = 'extent', 'multipoint', 'point', 'polyline', 'polygon')
The FeatureLayer is defined as such:
    const template = {
      title: "Predicted Wind Bands",
      content: "Historical wind band for " + featureSet.features[0].attributes.EVENT
    let layer = new FeatureLayer({
      source: featureSet.features,
      objectIdField: "OBJECTID",
      geometryType: "polygon",
      popupTemplate: template,
      fields: featureSet.fields,
      title: 'Predicted Wind Bands',
      opacity: 0.8,
      layerId: 0,
where the response object is:
"displayFieldName": "STORMID",
"fieldAliases": {
"RADII_MPH": "RADII_MPH",
"OBJECTID": "FID",
"EVENT": "EVENT"
"geometryType": "esriGeometryPolygon",
"spatialReference": {
"wkid": 4326,
"latestWkid": 4326
"fields": [
"name": "RADII_MPH",
"type": "esriFieldTypeSmallInteger",
"alias": "RADII_MPH"
"name": "OBJECTID",
"type": "esriFieldTypeOID",
"alias": "FID"
"name": "EVENT",
"type": "esriFieldTypeString",
"alias": "EVENT",
"length": 50
"features": [
"attributes": {
"RADII_MPH": 74,
"OBJECTID": 1025,
"EVENT": "DELTA"
"geometry": {
"rings": [
-79.798922025999957,
16.61326374500004
called as:
function getTrack(id) {
    esriRequest(
      url,
        query: {
          f: "json",
          where: "STORMID='" + id + "'",
          outFields: "RADII_MPH,OBJECTID,EVENT",
          returnGeometry: "true",
          returnDistinctValues: "false",
          outSR: 4326,
    ).then((response) => {
      renderBuffers(response.data)
It is a syntax that I have used before and is very similar to response objects that have successfully created FeatureLayers before. I am quite unsure what is going wrong. Any help would be much appreciated!
