feature report widget fails when using published web layers
257
05-21-2026 11:29 AM
RachelMassa
I am consistently getting error:
Status: Failed
Message: An error occurred when querying data from the feature layer. 400: UNKNOWN_ERROR Unable to perform query. Please check your parameters.
when using the Feature Report widget from a layer that was published from ArcPro as web layers with multiple layers in the map. I have tried removing all other widgets from the experience builder, hard coding the feature report widget to only use a single record, and modifying the report template to only have ${OBJECTID} in it.
The widget works if the data connected is a single hosted feature layer.
My main goal is for the widget to report related records, which from my understanding is only possible if all related features are in the arcpro map when it is published as a web layer.
