Feature Info widget does not select/zoom to related feature.
387
03-24-2026 11:58 AM
MollyE
I am trying to have Experience Builder emulate what the Map Viewer does when selecting a related record from the pop up of a feature. In Map Viewer, you can view and select related records, then click "Select feature" and it will select and automatically zoom to that feature in the map. When using the Feature Info widget in EB however, it does not do this. I have played around with different action settings to select and zoom to upon feature selection both within the map widget and feature selection widget with no luck, the best I can get is it auto-selecting every related record, which is not useful for my case.
It works as expected when using the Map widget's pop up, however these pop ups lack the customization and placement options that the Feature Widget has, so it is less than ideal. Is there a way to have the Feature Info widget select/zoom to the selected related record?
Below is a video of how it work in Map Viewer vs EB for me. Video editing is not my forte so please excuse the horrendous censoring. 😅
(view in My Videos)
Ke_Xu
by Esri Regular Contributor
Hi @MollyE,
Are you using ArcGIS Enterprise or ArcGIS Online? Also, would you mind sharing a sample app with me?
Ke
